2019 16” MacBook Pro audio
Which Apple laptops can exceed the sound quality of the 2019 16” MacBook Pro right now? That one rocks, and I was wondering which ones can best it.
The 16" Macbook Pro is the only one on the level of the 2019 16". The M4 exceeds in some dimensions (e.g. it’s overall louder), not all. If you really like the bass sound of the 2019, you might find the M4 16" to sound like a small downgrade.
Notebookcheck has detail in the speakers sections.
Thanks, I definitely do like the bass sound of the 2019.
None of the modern MacBooks can really come close to the sound quality of the fans of the 2019 16" MBP :grin:
