I’m trying to create a 3 monitor setup for my MBP. Usually my Mac is in clamshell mode, so, I want the 3 external monitors to be attached to it. According to the spec, it just allows 2 external monitors…
Have any of you successfully connect 3 external monitors?
While we are waiting for someone smarter than me to give the correct answer, have you considered going with a 34 or 38 inch UltraWide? Might negate the need for 3 separate monitors?
