A couple of Zotero integrations
Google docs:
https://www.zotero.org/blog/google-docs-integration/
unpaywall:
https://www.zotero.org/blog/improved-pdf-retrieval-with-unpaywall-integration/
Google docs:
unpaywall:
I am surprised there is not more discussion about The Archive text editor. Maybe all the zettelkasten stuff confuses people.
Itās a pretty good app - a kind off nvalt upgrade.
Itās been discussed quite a bit actually - https://talk.macpowerusers.com/search?q=archive%20zettelkasten
IMHO the reliance on long date-time stamps for linking clutters it up too much. Iād much rather use the title of a sheet in Ulysses and have the id hidden, as discussed above in this thread.
Interesting workflow: Scrivener, Endnote and Nvivo:
I like the deliberateness of writing annotations on everything one reads. Not so sure about committing to NVivo though at $700 or so for a license once the PhD is done. Iād want to know how it does its PDF annotations.
I am currently suffering buyerās remorse ($800+ but fortunately all grant and institutional funding) with MaxQDA as it uses Foxit PDF instead of the native PDFKit on the Mac, with the result that text selection and copy/paste donāt follow Mac standards and import/export of annotations into Preview etc. is impossible.
NVivo doesnāt āannotateā PDFs in the way we typically talk about. So you can code (or āadd nodesā to use the parlance) to a PDF, and export that PDF in such a way that it will behave like a PDF annotated in Preview or PDF Expert or PDFPenPro. In other words, the marking-up you do in NVivo doesnāt translate well outside NVivo. Of course you can use NVivo to export your nodes and other excerpts, which is useful in its own way. But if you want to have portable highlighted PDFs, NVivo is not your tool.
Almost identical on my end. Great set of tools.
Iām looking for apps that work well together in split screen. I.e. Bookmarks and Ulysses. Iām trying to find a PubMed app that will split screen with other apps. The one Iām currently using floats, but wonāt split screen.
Hello everybody,
I currently work on my PhD (political science) and donāt really like my workflow. I used to rely on Devonthink and Scrivener. However, I am not that satisfied anymore. When not at home I work on my iPad Pro (iMac at home) and especially for Devonthink it feels like it is only an afterthought to the developers, i.e. no open-in-place functionality. Additionally, I often have syncing issues. Scrivener on the other hand feels clunky and not well-suited for iOS.
Therefore, I look for a workflow which better fits my needs. A workflow I would like has to tick the following boxes:
I use Ulysses for blogging, do you think that it could be an option for my PhD as well? Or does it miss anything, one definitely needs for academic writing? And do you have any idea how to link to reference material in iCloud folders?
Thank you very much for any suggestions!
Brett Terpstraās Marked 2 app includes working with multiple markdown files (as chapters:
I have 1.1 million words of reading notes etc. in Ulysses but I canāt imagine writing a dissertation in Ulysses (having written three in WordPerfect 5.1 to 8ā¦which wasnāt ideal but which Iād probably use in favor of Ulysses still if those were my only optionsā¦). I donāt think its organizational features come close to whatās possible with Scrivener (which Iāve used for nearly everything Iāve published, since switching to the Mac on my 1st postdoc). I use Markdown for the first draft of probably 90% of what I write these days but once you get to second and third revisions, responding to reader comments, etc., Iād expect youāre going to want the additional organizational and markup features that Scrivener makes available. By all means write in Ulysses if it lets you get everything on the page - its export is good and easy, too - but donāt expect to keep everything there.
I donāt know of any app thatās available for academic writing that is excellent on both iPad and Mac. If youāre intent on writing in Markdown then of course you donāt need to use one single app, although niceties from a dedicated Mac app may not be accessible.
If I were writing a dissertation that utilized references from something like Zotero/EndNote/Mendeley Iād consider a specialized Mac app like Manuscripts, whose workflow is similar to Scrivener on the Mac but is designed for academic writing. (Note: I have not used this app.) The main downside to it is that it is not cross-platform, and Iām not sure it works with iCloud.
https://www.manuscriptsapp.com/
Ulysses could be an alternative given your listed requirements, depending on how youād intend to insert reference links. In this Reddit thread, the top-poster describes using Ulysses (along with LaTex, TexPad and Citations) for his/her thesis:
I had high hopes for Manuscripts, even bought it to encourage them. It is now open sores, and still not reliable enough for me to play with it without crashing or other problems. I cut my losses.
Ah well. I did the same thing, paying 1.5 years ago for Gingko, but itās still not in the kind of shape where Iād trust it with extensive writing.
Rather than jettisoning a system that has been working for you, maybe you can determine why you arenāt satisfied. You have tools you are familiar with, and they have been working for you. What problems are they not solving for you now? Is it because your dissertation is difficult, rather than the tools?
Also keep in mind you donāt have to work on the whole document at once. You could work on a particular chapter (or paragraphs) on your iPad, insert references to be fixed when you get back to your iMac, etc.
Finally, if jettisoning Scrivener is the correct solution, I would recommend looking at thesisdown and its derivatives for various universities. Thereās also Tyson Barrettās workflow using RMarkdown and LaTeX class files for formatting and layout.
Iām evaluating both for my dissertation writing. (Did I just write that
Same. My Gingko is withering in my Applications folder. Itās such a novel and interesting paradigm too.
If you can identify one person whoās completed a dissertation (tenure is too high a barā¦) purely in Markdown I will be astounded.
Hereās one
I wrote my PhD thesis using Word and folders on a hard disk and it was not a pleasant workflow at all, but back in 2003 there were not many options. Now for longer publications like journal articles I use Scrivener and DEVONthink on the Mac and the combination is a joy. I always feel in control of the writing and confident I can access my research materials easily. Honestly, I couldnāt imagine better tools.
On the iPad they are nowhere near as good, but I think youāll be hard pressed to find better.
For short publications I use Ulysses but itās not suitable for writing a thesis. Keep It is another option, but this is not as full featured as DEVONthink.
Thereās also Texpad, which is amazing.
Copy/paste isnt working for me on iOS beta, but search here on the forum for more details.
