I’m looking at upgrading my M1 MacBook Air (16 GB/2 TB) to an M5 Pro MacBook Pro. I’m looking at sales and refurbs, and I’m seeing about a $750 difference between a 24 GB and 48 GB machine (the more expensive one also has the nano texture display).
I tend to buy higher end refurbs and keep them for 5-7 years. The M1 Air is creaking under the strain of some of what I’ve been throwing at it - especially audio transcription and some light vibecoding on personal projects. JUst trying to figure out whether the extra $750 is worth it for the bump to 48 GB of memory, which I clearly do not need today, but which I imagine will become more useful in several years, and I don’t expect memory prices to drop anytime soon. (I do not currently use local LLM’s, but can imagine that changing in the future.)
It makes total sense in terms of longevity. Who knows what memory requirements will macOS 28 have?
Keep in mind that 48GB anyway is today in the low bar for local AI development son don’t set your expectations too high: I have a 128GB M4 Max Studio and although the machine is incredible with everything else I’m pretty underwhelmed when using local inference. (I’m not saying that you cannot do anything and you should go for a higher specced unit, though, local inference models and engines are getting better on the same hardware every couple of months).
With the continual changes and Apples deprecation of many devices this year, I’ve resolved to buy only bog standard and make my upgrade cycle shorter if necessary.
A top range mega expensive device might deprecate faster than expected and not be worth longevity.
Thanks, all. I wound up getting the 48 GB model - I’m already using it to do some file organization via local LLM rather than Claude. Definitely more machine than I need at present, but I think I’m set for some time.
I am definitely taking some time to get used to the transition from a sleek M1 Macbook Air to a relatively chunky M5 Macbook Pro. (Fans! Heavy!) The most interesting bump in the road was realizing that I relied on the wedge shape of the Air when I picked it up, to tell which side to open!
