In my last thread, I asked about choosing files and notes for an AI task. One reply described using Claude to review an existing workflow and draft a handover manual. That made me think about what happens after the answer becomes something you actually use.
Suppose you use AI to help write a project proposal from some reference PDFs and notes. You review the draft, keep some parts, change others, and save the finished document.
A week later, the proposal needs updating. You open the file again. The text is there, but the reasons for some choices may still be in the AI conversation, while the supporting information is in the original PDFs and notes. Perhaps you left out a section because it wasn’t relevant to the first version, but now you need to reconsider it.
Or consider an AI-assisted handover manual based on procedure documents and a spreadsheet. Later, the spreadsheet changes. Before updating the manual, you may need to check which instructions came from that sheet, which came from the other documents, and what you changed yourself after the AI’s draft. Reopening the chat gives you the original exchange, but not necessarily the current state of the work.
Sometimes the document alone is enough, and going back through the conversation would add nothing. Other times, understanding why a paragraph ended up that way matters before you change it.
This feels like a different problem from choosing what to give the AI at the start. The work now includes a document you’ve edited, the sources behind it, and possibly a conversation that explains some of the decisions. They may all still be available, but they aren’t necessarily in the place where you resume working.
I don’t think every AI-assisted task needs a new record-keeping process. I’m interested in how people handle this in the tools they already use, including cases where the finished file is all they need.
When you return to a document you worked on with AI, what, if anything, do you need to look up again before you can continue?
