After upgrading to Mojave, my iMac never turns off. I have done everything I can, but it just stays on. Not even the screensaver comes on. Settings attached. Any ideas?
First I assume you shutdown the iMac and restarted it. Next I would reset the SMC to see if that will fix the problem. https://support.apple.com/en-us/HT201295 If you still have issues a PRAM reset may help https://support.apple.com/en-us/HT204063 Let us know if this helps.
Have you tried to adjust the sleep schedule? Mine was doing this too until I dropped the schedule down to 2 min for a day. Once I did that then it worked as expected and I was able to bump it back up again.
Do you have anything attached to it? Like a thumb drive or thunderbolt attachment, even another monitor… ?
I will try this, thanks!
@Barry Thanks for the response! I will try this if adjusting the settings a couple times still doesn’t work.
