AirPods Pro Mic not working
I did the update yesterday to ISO 17 and apple also updated the firmware to my AirPods Pro. Now the microphone is not working. Any idea on how to fix this? It worked fine yesterday.
I guess first step is to ensure all the settings for the AirPods in iOS enables the mic. Perhaps something turned off.
The mic on mine was disconnecting from time to time before the upgrade. The solution was to disconnect them, then reconnect them in Settings/Bluetooth.
Thank you disconnecting it and reconnecting It seemed to get it back on line working.
