AirPods pro tips
Here is a pro tip I found out by accident
I listen to podcasts in bed most times, and I often felt AirPods took too long to connect and almost always had to connect manually through control centre
I finally know why, it seems that AirPods use their accelerometers to “wake up”, so putting them on in bed wasn’t quite doing it, this is probably made even worse by using one of them which is what I do
try it for your self, put one AirPod in and shake your head a couple of times, it wakes up almost instantly!
Sometimes it does seem like it takes awhile. I will have to keep this trick in mind.
I do exactly the same thing.
Aaaah, thank you!!! Great tip! :smiley:
Great tip, I’m going to give it a try! :slight_smile:
