Long story short, I have enabled alternate pointer actions to use a device that doesn’t work with Monterey. This means I raise my eyebrows to click while this device is plugged in and it’s… kind of awesome.
Under System Preferences → Accessibility → Pointer Control → Alternate Control Methods, I clicked “Enable alternate pointer actions” then “Options” then removed all the default functions and set “Raise eyebrows” to “Left Click.”
I’ve also been playing with head pointer, where I move the mouse with my head and then smile to park it somewhere (and smile again to be able to use my head to move it).
Wow, I had so much fun, navigating the mouse with my head!
Though there was a lot of drift for me, I think I would need some more fine tuning, to make it work.
Is there a way to tie the facial expressions to a shortcut or something?
