I’m so sorry: my fault! My “Copy text as lower case” was a very simple workflow I’d made. Sorry for misleading you.
It’s actually incredibly easy to do something like that. Start a new workflow with Trigger > Universal Action. Name it (when you double click it) and check it to show for “Text”. Then connect it to Utilities > Transform - which will give you a box that if you double click will allow you to choose from Trim Whitespace, Upper Case, Lower Case, Capital Case, Reverse String, Strip Diacritics and Strip Non-Alphanumeric.
Once you’ve done that, and chosen the transformation you want, just add Outputs > Copy to Clipboard and connect the Transform box to that output.
You should end up with a worklfow that looks like this:
It all takes longer to explain than it does to do so don’t be put off by the lengthy explanation!
Stephen
