Hello,
I had to work on a Numbers sheet yesterday, and needed to update the background of a cell. On Macos, you can achieve this with the inspector on the right side. But I couldn’t figure out how to do that on Numbers for iPad… any clue ?
Thanks
Hello,
Thanks
Select the cell(s) you want to format. Tap on the brush icon on the top right, then tap on the “Cell” tab, and the bottom of that menu has the control for changing the fill color of a cell.
Cool ! I was lost in all the menus ! Thanks
(sorry, the screengrab is in french Well, not sorry, now you can learn french too )
