I had no idea this functionality was in raycast!
The Due Date field responds to natural language too. ![]()
Thatās an issue with Raycast. It is certainly a powerful tool, but itās kind of hard to discover what it can do.
Thanks everyone. What a great bunch of people in here.
Iām going to take a closer look at Raycast and Instaremind!
How would you compare Raycast to Alfred? Iāve used Alfred in the past but before I reinstall it I should probably consider Raycast as an alternative. Any thoughts?
I only use Raycast as an app launcher, so thereās not much difference between Raycast/Alfred or Launchbar which was my old love.
Apart from the discoverability issue these tools have (what can I do with that prompt? Read the manual, really?) Raycast covers a lot of stuff that you would do with a handful of other apps. See, for example, window management, reminder creation, calendar stuff, keyboard shortcuts and of course launching apps.
So itās basically a matter of taste. Raycast is free as in beer so giving it a chance only takes time ![]()
Thanks for response. That last sentence gave me a chuckle! ![]()
As Herbert Spencer said: time is that which man is always trying to kill, but which ends in killing him.
I keep a bookmark to Alfredās Cheatsheet in my Safari Favorites on my start page. I frequently review this page otherwise I forget all that Alfred can do.
Thereās a good thread on exactly that topic:
I can only download it from AppStore and it cost $2.99.
Youāre right - my bad. It did cost something. Itās been so long I had forgotten.
I hate how I canāt tell what an app costs in the App Store once I have purchased it!
Same here! There should be a method for that, to see what past purchases have cost.
Hi bowertune ā Just wondering if this (Instareminder) is still in development because I just came across this forum (my first post) because Iām looking specifically for this solution (since switching away from Things). I just downloaded it (for $2.99) and itās not working. I am on a brand new MBP / M1 Pro / running Ventura (13.1). Not getting any help from the dev.
My instincts tell me that (because Apple has slowly been removing access to their Reminders API) if nothing will work anymore. (I also used that AppleScript, it worked once⦠but no more).
Thanks for any clarification or status update on Instaremind (or other solutions).
Hey @meatface - I no longer have that installed, actually.
Has the Apple Shortcuts app worked for you? I find that it is pretty fast now. I just tested out the āAdd New Reminderā Shortcut that populates when you search for Reminders in Shortcuts, and it is lightning fast, especially when assigning a keyboard shortcut. Could be that the Instaremind dev is no longer supporting. I would try the Shortcuts app.
I know this is an old question. But this is how I solved this need in Ventura without additional software, in case it helps folks:
Now I can create a reminder by holding Opt-Space, and typing something like āremind me next Monday to do the laundryā
Just came acros this topic and wanted to let you know about a very good soloution that I use. It does however only work as a combination of Alfred and FantastiCal. It“s an Alfred workflow called: Fantastical Alfred Workflow.
With this you can not only create a Reminder but also a calendar event right from Alfred. Been using it for years and it“s really good.
Link to the Alfred Workflow
