To update my Sony A7s iii on Big Sur seems to be a problem. Sony’s says its updater software is not compatible with Big Sur. I can’t see any options to update. Possibly to just wait, or buy a windows machine? Not sure I can segment a drive and install a windows compatible provision on my iMac? How difficult is this …I’m not very savvy on messing with my Mac. Any thoughts would be appreciated.
Author
Okay, I gather Sony does supply a patch as below… fairly involved but hopefully doable … https://www.sony.com/…/e-m…/ilce-7sm3/downloads/00017019
Sometimes we have to give up and find a PC to do the firmware upgrade
Perhaps you can have your camera store can do it for you.
Yes… possibly dragged kicking & screaming to buy a windows machine…unfortunately bought the camera from an store a few Canadian Provinces over … our area very limited on camera sales. But, thank you for your input …appreciate
See if they have a linux version and get a Raspberry Pi
