I’m MacOS Mojave and have been since the launch on a mid-2013 MacBook Air. Last night the fans just started spinning up like crazy because “CalendarAgent” is running out of control.
I use Fantastical so if I quit that app and quit the “CalendarAgent” in Activity Monitor it goes away. But within long it’s back again.
Anyone else seeing this or have any possible fixes?
I assume you are syncing your calendar to either iCloud or some other caldav server? In that case it might be a corrupt calendar item that’s causing issues. Have a look in the console app to see if you can identify that calendar item.
