I have a question for a round trip type Workflow. I have downloaded 1Writer for my long text creator and editor to save into DTTG. Although I open a DTTG plain text file in 1Writer and do some editing and try to save the changes back into DTTG but it hasn’t worked so far. Am I missing something?
My steps:
Open my file in DTTG
Click the share button
Select Open in…
Make changes in 1Writer
Press send
But I don’t see changes to original file within DTTG.
You say you are selecting “OPEN in 1Writer” in DTTG? Are you sure you are not choosing “COPY to 1Writer”? I do not see “Open in 1Writer” or any other app in DTTG, and I do not believe that “Opening in” is possible from DTTG.
What happens if you:
Create the file in DTTG as you have been
Switch to 1Writer
Tap the + button in the bottom right and select “Open Other”
Navigate to the file in DTTG from step 1 using the Document Provider
Make your changes.
Do your changes show up in DTTG after that?
An alternative:
In the Files app, locate the file you created in DTTG, long tap>Share>Open In 1Writer.
