I’m in Burlington and mostly tinker with small personal projects on my Mac. I have an idea for a simple app that would organize some reading lists and track notes. It’s nothing fancy, but I’d like it to sync across my devices.
I keep seeing mentions of AI app builders and wondering whether they’re a reasonable first step for someone like me, or whether traditional development is the better path even for a small project. My main concern is getting stuck with something that’s easy to start but hard to change later, or that locks me into a platform I don’t understand. I also don’t have a background in programming, so I’m weighing how much learning time is realistic.
Has anyone here tried building a personal app with these tools? I’d like to hear where they worked well and where traditional development made more sense. Any input from people who’ve done this would be appreciated.
One data point missing from most vibe coding/AI app development discussions (everywhere, not just here) is the real out-of-pocket costs.
Unless I am mistaken, the AI frontier models needed for app development do not run locally, so there is a real cost of AI tokens and monthly subscription fees.
I don’t want to pry, but I am very curious what it actually costs @MacSparky and @beardfm, and others, to build and maintain the AI apps they have talked about.
I know the rudiments of programming, but I’m by no means a coder. I’ve used my Claude subscription to build and maintain several basic native Mac apps for my personal use and plan to build more. It’s fun and it’s straightforward.
I hasten to add that Claude does all the building and maintaining; all I do is outline what I want the app to do and Claude does the rest. Unless you want to learn how to build apps “by hand” (and that’s a fine thing to want to do), I don’t think there’s any real need to do so, assuming you don’t mind paying for AI. You can get a lot done with a $20 per month subscription.
The process is iterative: you and the AI will have a conversation what you’d like the app to do, what you’d like the UI to be like, any existing apps that have some of the features that you want, etc. Ideally, the AI will ask you clarifying questions about your intentions and your preferences. You can also ask if your subscription will cover what you want to build, or, if you’re using the API rather than a subscription, how many tokens you’ll need to buy to get the job done. And if you want to make changes later, you just ask for them.
I’ve also used Glaze to build a Mac app. It was fine, but I preferred just using Claude since I already had a subscription.
I’m on the cheapest Claude plan, but honestly I got started on the free plan and it was fine as I wasn’t in a hurry. I built my first app over weeks. Paying just enabled me to move faster and now I also use it for other tasks.
I created an app on the Claude $20 a month. I found it trickier than I thought as you need to know exactly what you want including how it looks, tabs or extra windows, formats, syncing, backup, etc, etc, etc. It’s worth doing one simple app first to give you an idea before you look for more difficult apps.
