Hi
I am new to the group and looking forward to participating.
Can anyone tell me how to create a custom perspective to show only projects (no tasks) the match a certain condition e.g. all projects that have a defer date
Thanks
Bobby
Hi
Thanks
Bobby
You can use a None of the following:
group with a Is not a project or group
rule.
Like so:
I’ve also set it to ‘group and sort’ by entire projects, as it looks a bit nicer.
You can place the Is not a project or group
rule inside the None of the following:
group using drag and drop, if it doesn’t appear there automatically.
Make sure you have the indents right. Otherwise it can result in strange filters
