Hey @JoeBuhlig et al., I keep setting my interface preference to dark mode and clicking save, get a confirmation, then go back to the home page and it’s back to light mode. Have tried restarting Safari and opening in Chrome, but I get the same result each time.
Dark mode is working in my other two Discourses though (PG and Drafts).
If you are experiencing an issue switching themes I suggest clearing your cache (at least for here) and trying again. We haven’t changed anything on the forum and it’s working on the devices I tested on.
So I cleared the cache on my iPad and dark mode will not activate. I also went to my MacBook Pro and it appears that when I select Dark off the hamburger menu it appears to be grayed out in that I try to select dark and all that happens is it will turn yellow and nothing happens. Very strange.
Hi Rosemary. In reference to Dark Mode not working with Discourse a funny thing happened. When running iOS 11 Dark Mode worked fine until one day it just would not change from Light to Dark. I followed all the suggestions to try and get Dark Mode working again and nothing worked. Then I loaded iOS 12 Beta version 10 (public beta) and just like magic Dark Mode is back. Since iOS runs everything in a sandbox there just isn’t a lot for me to poke around and see what may have changed. Thanks for the help and we can just file this under thing that make you go hummmm.
