Not sure what I am doing wrong, but I can’t get Shortcuts to disable Do Not Disturb via shortcuts. I was trying to make a “take a nap” shortcut.
Anyway, have created a test shortcut (in screenshot) and I would have thought it should switch on do not disturb when run, then 10 Sec later disable it. First not happens, but switching off again doesn’t.
Thanks. So that seems to work. The key point being that I should set ‘until’ a time and then define time with the variable rather than ‘until’ variable.
