So are you opening the Numbers files from Dropbox, or are you going to the Numbers app and opening them there?
Opening them from Numbers works as expected. Opening them from Dropbox opens a āQuickLookā type view, so if you want to work on the file, youād open Numbers first.
Does that cause a problem with your workflow? (It doesnāt for mine.)
My experience (and also what I have read of other peopleās experience) is that Dropbox is more reliable than iCloud. I use both, but I use iCloud Drive only because that is where Pages and Numbers files work best. Remember what started this thread, a post about the unreliability of iCloud.
OK, Iāve learned something, and we now are on the same page. If I am in Dropbox and find a file that may need editing, then I should go to the Numbers app or the Pages app to find and open the file. I was wanting to open the file directly from Dropbox as I would in macOS or Windows or as I would open an MS Office file with Dropbox integration in iOS.
Does it cause a problem with my workflow? It seems somewhat inconvenient, but certainly easier than exporting the āQuickLookā version as I was doing previously. So, thanks for the info.
I agree completely. Itās the only service you can 100% rely on. Iāve had issues many issues with iCloud in the past and I donāt use it for work data, only personal stuff.
I keep iWork files in DevonTHINK to quickly search and access all my files together, and these can be edited and opened on mobile. That solves this problem for me and lets me use DropBox to sync.
Thatās fair enough!
But have you tried opening the spreadsheet from the Files app? I.e. Donāt use the Dropbox app, but the general Files app that comes with iPadOS. If you edit the sidebar in Files, you can add Dropbox as a location, and have access to all your Dropbox files that way. You can add any Dropbox folder to Favourites, so it should be just as convenient a method.
Iāve just tested it, and when I opened the same test Numbers file, it opened Numbers itself in the way youād expect.
Secondly, if you really need to use the Dropbox app, then it may be possible to write a Shortcut to open files in Dropbox in Numbers or Pages as it seems exactly the sort of thing that Shortcuts is designed for. (Hopefully someone reading this knows how to do this and can help, as Iām afraid I donāt really know my way around Shortcuts well enough, sorryā¦)
HTH.
This works very well. Iāve done a fair amount of googling on how to use Pages and Numbers files in Dropbox, and I never ran across this. Maybe you should be a tech blogger.
Thanks again.
Iām glad youāve found something which works for you!
Iāve been experiencing Finder operation slowdowns since upgrading to Sonoma (14.1). When I move or copy files, Iāve been greeted with a āpreparing toā¦ā dialog and a wait of many seconds, even when dealing with only one file.
The culprit appears to be Appleās fileproviderd process, which serves cloud services. Disabling OneDrive and Google Drive, which I wasnāt really using, had minimal effect.
Today I disabled Optimize Mac Storage as a means of reducing iCloudās instantaneous synchronization demand. Now files move and copy at full speed, but the Item Info for several files is shown as āineligible.ā My files have multiple backups, so Iām willing to risk problems in order to alleviate this Finder headache, but this is concerning.
Update:
Moving āineligibleā files restores their Item Info. Part of Sonomaās iCloud and Finder issues, apparently.
Also, the fileproviderd cloud sync process was clearly a problem, as it consumed in excess of 100% CPU usage. However, terminating it (which required more than one attempt to accomplish) did not by itself speed Finder operations appreciably.
Before I upgrade to Sonomaā¦
What if I run the upgrade, and wait (patiently) for my files to āresyncā - will everything be OK?
Impossible to guarantee, but Sonoma is working very well and without any problems for me after some initial issues (not only iCloud Drive, but the disk optimisation took days and showed as a few apps crashing on launch).
I just did it. Everything is smooth.
Sonoma just works.
Howard Oakley has published a follow-up to his first post:
His conclusion: the changes MacOS Sonoma has implemented in file handling on iCloud Drive has improved reliability. The āupgrade processā that led to some raised eyebrows also in this community seems to remedy issues introduced in previous OS versions.
Sonomaās changes to iCloud Drive run deep, and so far (on limited testing) appear to increase reliability and make the choking of actions far less likely.
So, upgrading to Sonoma is not the issue but the solution to potential issues regarding iCloud Drive. (Both of my Macs are running on Sonoma, with no issues.)
Typical Apple⦠not only ājust trust us that it will workā but also āā¦ā¦ā when it doesnāt and āā¦ā¦ā when they fixed the problem (that was never broken).
So perhaps āIt just worksā should be amended to āIt just works, eventuallyā. I feel thatās both more accurate, and also timeless.
Or, more succinctly⦠āGood luck!ā
I have read the article 3x so far and I am still struggling⦠I upgraded to Sonoma when it came out. My dilemma is that every night I go to sleep and all my files in iCloud are on my computer. I wake up in the morning and all evicted. I need to redownload them all again. (or at least whenever I am working on a file) Itās getting to the point where itās not worth using iCloud to store files if this keeps happening each time.
Is there a sequence of steps to follow to avoid this from happening?
Or is this just the new reality I need to accept?
Do you have āOptimize Mac Storageā turned on?
I donāt have Sonoma to give you a screen shot, but in macOS 13.6.4 the pertinent setting is in the System Settings ā Apple ID ā iCloud, not in General ā Storage. So might be there.
Just checked my settings⦠āoptimize mac storageā is turned ON, which according to their description⦠āthe full contents of iCloud will be stored on the macā
Am I doing something wrong
