icalBuddy calendars will show a list of all of the calendars that icalBuddy can see. That may help too.
See https://hasseg.org/icalBuddy/man.html for a full list of commands.
thanks for that tip on calendars - I can now see all my calendars bar one (for some strange reason one Google calendar appears in my fantastical OK but icalBuddy does not pick it up).
I’ll have to do a bit more digging on goggle site
UPDATE: found a way round the problem by subscribing my recalcitrant google calendar so it’s now visible, and I had to turn off the regular gmail calendar account in fantastical to prevent double appointments.
One more thing, now its working (with one calendar), when it finishes the last appointment, the tiles stays on red and does not go onto the fantastical icon.
UPDATE: read through all the macros carefully and found I’d missed the column number off the end of the important macro!!
Thanks for your support and patience with a (very rusty) programer!
You’re welcome! I’ve received lots of help over the years myself, so I’m glad to ‘pay it forward’.
unrelated question, can it show upcoming meeting in Mac menubar?
Hello! I’ve been relying heavily on the calendar event notification system that @tjluoma set up, but I’m having trouble getting it to work on the Ventura public beta (I know, I know, betas…). Has anyone else run into issues here?
I think the problem, unsurprisingly, is with icalbuddy. Even using TJ’s updated version, I get error: no calendars when I try to run the script in Terminal. I assume that’s why I get to stare at Fantastipal all day when I know I actually have meetings.
All of this to say: Has anyone else had issues on Ventura and have you found a fix?
Thanks in advance!
I would love to install / use this but on the new Better Touch Tool implementation of Stream Deck commands. Will this work with that, or no? Thanks!
Bumping this up again as I update to the GA release today and am once again getting the error: no calendars message when I run icalbuddy from iTerm. Any suggestions on where to start @tjluoma et al?
Just following up over here too… I fixed this with a shortcut and modified the next meeting macro thusly:
I also renamed the set color macros to remove the button name in their title because I’m wasn’t sure which button I was gonna use ![]()
It took me a long time to grok what I’d use this for; I had a mini and then upgraded to the XL.
Just recently I took the initiative to add shortcuts to SD keys and I absolutely love it.
I use several plugins and some Mac specific tools like KM Link and Shortcuts and I also use a FCP X Profile I created from scratch.
Hello @tjluoma I gave it a try and noticed a few things, iCalBuddy looks like it no longer works and is out of development, or does not work on Apple Silicon? There is a new tool developed in ruby that does the same thing called iCalPal. Has anyone tried it as an alternative to icalbuddy?
Is there an updated version of the km-icalbuddy script using [iCalPal]?(GitHub - ajrosen/icalPal: Command-line tool to query the macOS Calendar and Reminders)
I’m also running into the same issue with icalbuddy giving me an error of No Calendars.
Is icalbuddy still working for folks on Mac OS 15.1?
I am using the version from the GitHub repo for this from TJ’s link.
Unfortunately iCalBuddy does not work in the most recent versions of macOS. Or, rather, it works in iTerm/Terminal, but doesn’t work in things like Keyboard Maestro and launchd.
The utility is very old and appears to be unsupported at this point, so I’ve had to stop using it myself for this purpose.
