I’m now marking a year of using AI. I’m not going to talk about the benefits, but some practical comments. This comes out of needing to delete my Claude AI account as I’m moving to a team one.
Exporting all chats was impossible. Also what used to be cowork that has been changed also messed up cowork chats.
I create a prompt that would allow me to continue any chat in my new account when it is set up. In total I had 130 or so chats. I only needed to save about 30%. Asking my prompt to work through that 30% burned up two of my Claude usage limits. So if you have more beware! The process also took about 5 hours. I also needed to work on one chat at a time.
The most annoying aspect that I was not aware of is that Claude seems to save the chats on the device you create it in. I deleted all the chats in the macos Claude app and some 45 chats where still there when I asked, but I could not see them. I then logged into the web browser where 20 chats appeared and after after that onto my Pixel phone where the last 25 appeared. The mobile phone ones I didn’t need to back up which I’m glad about as this would have been a pain to export.
The final aspect was that some had been archived and I needed to change the view to see them and sort those out.
My conclusion is that I will no longer leave any chats in Claude. I will use a prompt to export it so that I just need to paste the prompt and continue where I left off. This might seem a pain, but not as great a pain as needing to get your data out.
I’m a Doom Emacs user and must say Claude created a really good export prompt that created org documents that I save into my folder. The org docs where fully formatted and will be easy to reuse should I need to.
Finally, I’m glad I did this after a year. If this was after 3 or 5 years it would have been a nightmare.
I’m just posting this here in case you’ve got a ton of chats in your AI, or you’re looking to switch AI’s and need to get your data out.
