Fix Sidebar Icon?
Hey MPU,
I am not sure what happened to my icons, any suggestions on how it just changed and there’s no blue outline?
Screen Shot 2022-01-03 at 1.59.40 PM
Have you tried removing the sidebar item and re-adding it?
I did several times, normally I wouldn’t be so nitpicky, but it keeps calling out to me. LOL
Have you tried running “First Aid” on your disk from the Disk Utility? (Reboot after running)
Whenever I add a sub-folder of Documents to the sidebar, I get that grey “document” icon – without the blue outline. Monterey doesn’t do that for subfolders of Desktop, Applications, Library, or anything else. Nor is it logical that the icon for a folder would be the document icon.
I get the same thing on my MBP just for the Google Drive app. ?
