Hey All. Recently got myself a used 15 key stream deck, yay! I’m digging into some Fusion 360 mapping as I use the software for modeling, mostly for 3D printing.
There are many many features with keyboard shortcuts, but manipulating the view of the model is unfortunately not one of them. I want a quick way to reset the view to “home”. Well, quicker then mousing over to the home button on the view cube in the upper right corner. At this point, I’m a little resigned to it not being possible after reading years of threads on various forums that say “nope can’t be done”. So now I’m starting to reach out to places where people might have some knowledge. Have you solved the problem? Do you have a solution? Happy to hack something together. There is a scripting API for Fusion360 but in reading the reference guides, nothing refers to the model view. I stumble across a post about double mouse clicking the center mouse button and I was going to map that through better touch tool, but no dice there either.
Consider this my last-ditch effort before I throw the towel in. Thanks!
