I’m looking for help with a workflow that works with Apple Mail (IMAP account) on Mojave and preferably something similar to work on iOS. It would preferably we automatic via a mail rule, but would also work by kicking off a workflow via Shortcuts (iOS) or hotkey combo on MacOS.
When I receive an email with an invoice (pdf) attached, I want:
The attachment saved/imported into DT Pro
The attachment forwarded via email to a specific email address (i.e. x@x.com)
The original mail message archived
I can’t, for the life of me, figure out how to make this work. And ever since Workflow became Siri Shortcuts, it seems even more complicated to build a workflow than it was before.
Anyone doing something similar to this? Any suggestions on how to accomplish this?
Just wondering which mail service do you use?
AFAIK there’s no way of triggering Shortcuts upon event, but if you use a service that supports labeling, like GMail for instance, you could do this serverside which would then run automatically and only serve you with the desired result on you iOS device
I don’t really know that much about FastMail but I see they do support rules & filtering so I’m pretty sure you’d be able to do it through their web interface as stated here
I’d look into doing it that way, to keep it as simple as possible
In an effort to make this more cross platform and expand to more variations of the invoice pdf, I started building out hazel rules and applescripts for this. This way, regardless of what platform I’m on and regardless of whether it’s an invoice attached to an email or a receipt downloaded after paying an invoice online, I just save it to my Actions folder in Dropbox and Hazel handles the rest.
I hacked together two applescripts to handle the two actions of:
Forward the pdf as an email attachment
Import to DTPO, OCR (again), tag, and delete from Actions folder
It’s been working pretty well so far, but the only problem with email script is that the content for the body of the email is white for some reason. So the text doesn’t show up in the email unless you highlight it and copy/paste out of there.
Any ideas why the default text color would be white?
Here’s the email script:
set subject_ to "Receipt (Automated)"
set the_content to "This is an automated receipt notification..."
set email_from to "me@nope.com"
set email_to to "you@nope.com"
tell application "Mail"
set newMessage to make new outgoing message with properties {visible:true, subject:subject_, content:the_content}
tell newMessage
set visible to false
set sender to email_from
make new to recipient at end of to recipients with properties {address:email_to}
# set color of the_content to {0, 0, 0}
delay 1
try
make new attachment with properties {file name:theFile as alias} at after the last paragraph
on error errmess
log errmess
end try
delay 1
send
end tell
end tell
If I uncomment the line to set the color, it creates a new message with the text the correct color, but it fails to attach the file and seems to cause Hazel to run in a loop and never progress to the DTPO script.
This script works for me, should be adaptable to your needs
set theMessage to make new outgoing message with properties {visible:true, sender:"your email",subject:"subject", content:"Content\n\nSignature" & linefeed & linefeed}
tell theMessage
make new to recipient at end of to recipients with properties {name:"recipient", address:"johndoe@domain.com"}
end tell
tell content of theMessage
make new attachment with properties {file name:theAttachment} at after last paragraph
end tell
delay 1
send theMessage
end tell
Thanks. I had to modify it slightly, but at least it got me a little further.
Now I’m able to watch it and see that it is creating the message with the content the correct color. Then it attaches the file. Once the file gets attached to the message, the text of the body changes color.
So, no clue why it is changing colors when attaching files. That doesn’t happen when manually creating an email and attaching files.
Alright, I figured it out. It is an issue with the way Mojave’s dark mode works. Basically, if you have dark mode enabled then any rich format email message you create that includes any “images” gets converted into some screwy HTML stuff. This is what is causing mail to jack up the text only after the attachment gets added.
The fix:
Open Mail
Go to Preferences, then Viewing
Uncheck “Use dark backgrounds for messages”
This seems to keep Mail from jacking up the message formatting and the text stays the correct color.
