I’m wondering if anyone has experience getting their battery replaced at the Apple Store? Is it hours, days, or over a week?
I’ve got a 2015 MacBook Pro that we rely on daily for work so we can’t be without a machine, but we’re getting the have battery serviced notice in the menu bar. It works fine off the charger, and we can always get to one (my work requires it be plugged in for 4 hours anyways). Just curious if that is something they do in house with an appointment or if it’ll be for sure days+.
My battery was not replaced at the Apple Store. I’m in Florida. They shipped it off to Austin, TX. I got it back less than a week later, but that was a couple of years ago.
Your battery will not be replaced at the Apple store.
How can I check battery life on my MacBook Pro from 2014? It’s not holding a charge for nearly as long and I’m thinking a battery replacement could make sense as well.
I’m on the latest stable MacOS (not Big Sur, I forget the others), and when I click the battery in the menu bar, it says service recommended. But there are other 3rd party apps (coconut battery?) that will give you more details.
