I have an abundance of screenshots on the desktop of this shared computer. I would love to sort through them, toss those we no longer need and create folders for each owner. The stack info says there are 407 and none have been renamed.
I see their name includes a date. Is there a way to separate them by date? Doing that would make easier to evaluate them.
What built-in tools or utility software do you recommend for sorting through these?
I look forward to hearing some ideas and solutions.
Thank you
Suppose you get a Finder window of these files and sort them by their creation dates. Then you should be able to just grab a bunch of them and drag them into a folder.
How many months are we talking?
If a “reasonable” number, you could search in finder in the folder for, say, 2021-11, ⌘-A to select all, right-click and create a folder from the selection.
Second option, put them in a Photos library, set up hotkeys for keywords (⌘-K to open the keyword manager), then just have at it. Later you can create smart albums based on the keywords.
