Does anyone know how to get both a vga signal and audio out of an iPad Pro 2018 model? This was easy in previous models that had a headphone jack. I’ve tried a usbc to vga with an additional usbc to audio jack adapter. No luck. I don’t want to lug around an Apple TV just for this.
The projectors I have at school use vga only. They use a 3.5mm cable for audio.
There are USB-C hubs out there with VGA and USB-C (this one, for instance).
I’m a bit worried about buying these hubs. I found one I thought was interesting, but the only reviewer with an iPad 2018 said the audio out didn’t work. I guess I’ll take the risk.
Thanks for the link Chris!
The linked one didn’t work. The review for hubs mention the audio not working. I wonder what’s going on.
Clunky, but perhaps try a low cost Bluetooth adapter in lieu of the headphone jack.
I believe the USB-C jacks on dongles are only for power pass-thru and can’t host another dongle.
You are correct about the usbc. I hadn’t thought about using a bluetooth receiver. I bought one that can emit and receive. Maybe ill get some extra use out of this thing at least.
