I’m trying to buidling a workflow that will automate some of the tasks I do manualy when i start a new projects.
I will start by defining the project, so you get a clear understanding of my problem.
The user will trigger a text input.
The input will be part of the name of a folder in a set directory, in this case, /projects.
When the folder is created, it will be given a sequential number so the name of the first folder will be “(PE0001) - Input”, the second one “(PE0002) - Input”.
Here begins the part I need help with.
When a new folder is created as I described above.
Capture the folders name, ( (PE0001) - Input )
Create a new OmniFocus project with the same name as the folder
Create a new OmniOutliner file with the same name as the folder, and place is within the newly created folder. The location is then /projects/(PE0001) - input)
Optional:
I’m not sure if this is possible. But in the source directory, /projects, there is an excel file named “Project costs” is there some way to capture the name of the folder “(PE0001) - Input” and ad it as a new sheet? the new sheet would have some simple formatting and a few formulas.
I’m looking around for a script that can help me, or maybe an Automator workflow but unfortunate I’m stuck!
Do you smart people have any suggestions to where to go from here?
# Here's an AppleScript solution for you Linkonlawyer
# Let's assume that your projects folder is called "Projects", and is in the top level of your home folder …
set projects_folder to (path to home folder as string) & "Projects:" # Change this to the actual path of your projects folder
set resultDialogReply to display dialog "New project's name" default answer "" with title "New Project"
set project_name to text returned of resultDialogReply
tell application "Finder"
# Get the previous project number
# This assumes at least 1 folder already exists "(PE0001) - project name".
set previous_project to last item of (sort (folders of (folder projects_folder) whose name begins with "(PE") by name)
set previous_project_number to characters 4 thru 7 of (name of previous_project as string) as string
# The largest existing project number is used to create the next project number, which adds +1
set next_project_number to characters -4 thru -1 of ("0000" & (previous_project_number + 1)) as string
set new_project_label to "(PE" & next_project_number & ") - " & project_name
# Make the new folder in Finder
set new_folder to make new folder at projects_folder with properties {name:new_project_label}
reveal new_folder
end tell
# Make new project in OmniFocus
tell application "OmniFocus"
tell default document
make new project with properties {name:new_project_label}
end tell
end tell
# Make new OmniOutliner document in project folder
tell application "OmniOutliner"
set new_oo to make new document
set oo_file_path to projects_folder & new_project_label & ":" & new_project_label & ".ooutline"
save new_oo in file (oo_file_path)
end tell
@RobertBlack Thanks, I saw that. The Script works amazingly! But I’m having problems adding the actual folder path since it’s on my Icloud drive.
I think the path should look like this:
set projects_folder to ( path tolibrary folder from user domain as string ) & “Mobile Documents:com~apple~:Me:Projekt:(PE0084) - Test” # Change this to the actual path of your projects folder
But I’m doing something wrong since I get this Script Error :
Finder got an error: Can’t get folder “Macintosh HD:Users:david:Library:Mobile Documents:com~apple~:Me:Projekt:(PE0084) - Test”.
