Is anyone else using the “Get File” command in Shortcuts on iOS 14 for a Dropbox folder?
I had a shortcut step that gets the list of files from a dropbox folder and show’s the list as an alert.
This worked fine on iOS 13, but on 14, instead of giving me the list of files, it just returns the root folder name:
If I switch to an iCloud folder, the shortcut works fine.
In googling, I see that this same problem happened when iOS 13 beta came out, but was resolved. is anyone else having this issue on 14?
FYI, if I choose “Show Document Picker”, I see a version of the same behavior. I can’t even select a folder:
