On my iPad, I want to copy a Bible reference to the clipboard, then run a shortcut that will take that reference and the API (see above) and paste back to the clipboard the results. Then I can paste those results in my text editor.
I have a Token for the API. I also have Pythonista on my iPad. I just don’t know how to put all these pieces together. Any savvy helpers out there?
Thanks!
I’ve followed the steps but I can’t get something like John 1:1 to work.
For the token text should it be: Token {{ abcdefg }}?
I believe this is where I’m messing up as I can do a quick look and it’s getting the text but stops after that and I have it set to get from clipboard and everything else is identical to the picture in this forum except I have my API key entered.
