I don’t think it’s the same developer. Dispatch is listed as being by “Clean Shaven Apps” and https://www.cleanshavenapps.com does not mention Due. There is an app called “Timers” which is vaguely similar.
Hi TJ, yes it is the same developers, just working under a new name. If you read the Due app blog, Junjie talks about the work on Dispatch. Anyway, Junjie/@jjlin responded tonight with:
@macsorce @dueapp @DispatchMailApp Thanks for using Dispatch. Dispatch is no longer under active development. As such, changes in iOS or Gmail end may cause it to not function. We decided it’s fairer to take it off the store.
I am not giving up. I would pay a subscription for Dispatch or any email app that provides TextExpander Fill-In Support. Spark is like Dispatch Lite without it. I am getting tired of asking developers to support it though.
I am using Dispatch. I was speaking about people that I recommend it to cannot download it even though it still works fine.
Huh. Curious. Thanks for the update.
Thank you, it worked!
