Hi all, I have an iPad Pro 9.7inch running that latest public beta of iPadOs (but this problem persisted long before I installed the beta) and it will not charge. I have a MBP 2017 with two USB-C ports and plug the iPad it into a Totu USB-C dock so that I can use it as a dual monitor (using Duet) and charge it. But it won’t charge. Is this a setting I need to change?
It syncs to iTunes when I plug it in and works fine with Duet, but says in the upper-righthand corner “not charging.”
