I used to use an app called vJournal and it would automatically timestamp the entries and create a new note daily with the date. They stopped developing it and I am lost. Does anyone have an app or a workflow that can fit this need?
Thanks
Thanks
I use PopClip, and one of the included extensions is ‘Timestamp’ which in any document I’m in lets me with a double click paste in date/time in this format:
2018-09-16 20:59:00
Hello @Manfernan
I have used 1Writer on iOS as a daily journal while on holidays.
It has a number of options in preferences including starting a new document each time you open the app, see pic below, and has a time stamp facility as well.
I like using markdown so it satisfies that need too.
When the app is first ooend there is a settings gear top left
In the app there are actions which can be freely downloaded that include time stamps.
Hope that helps. I also write the same journal using nvALT on the macOS. They are both stored in Dropbox.
Stephen
