My MM arrived, so I’ve Installed the latest OS update, 1Password, then started to install my applications.
The App Store seems to be broken. It shows there are 3 apps which need to be updated, clicking on “Update All” does nothing. Downloads do not begin, no progress nor errors are displayed.
I then attempted to install Remote Desktop and Jump Desktop, but the “GET” icon is not visible. Does this mean the SW is not compatible with Big Sur?
