BTW friends, I switched to Brave Browser (with all the same extensions) and set tracking, 3rd party cookies and fingerprinting to be blocked aggressively (browser’s feature). I’ve been using it for 2 days now and the temperature is baring going above 40C avg. Earlier used to be 50ish and the frame would be warm-hot. Now its room temperature.
I will still buy TG Pro that @cornchip suggested as I found it to be a great one time purchase, just in case. Will share a long term review of the temperature and app here.
just found out that it is 50% off at the moment, I agree this is great value
Brave rocks. It is such an improvement over Chrome. Your battery life will increase dramatically as well
Thanks for the info about TG Pro Had not known about this app. Also curious if anyone has a preference of TG Pro or iStat Menus?
+1 for iStat Menus with its broader range of capabilities. But if you’re just looking for temps, both seem acceptable. Both have been recommended and used by folks on this forum.
I prefer Turbo Boost Switcher Pro:
automatically disables Turbo Boost when the Mac gets too hot, enables fans, and all-in-all, it brings down the temp of laptop
Updating after a week of using Brave (with all the extensions) and the temperature has been < 40C all the time for my usage. This wasn’t the case when I was using Firefox. Leaving this review here in case it helps someone later.
I also think, the search autocompletion is very fast on Brave and my browsing speed is also better.
Is this really needed with the “Low Power Mode” in Energy Settings?
yes it still might be useful, I remember the developer testing both Low power mode used with Turbo boost and still seemed to help.
Reporting back after close to 1 year of using Brave. It is superb for my battery life. My mac hasn’t been hot for a while even with intense browsing or loading heavy web pages. Browsing speed in incredible as well!
