Having trouble with a MacBook Pro (Retina, 13-inch, Late 2013) with 16GB RAM and 500GB SSD. It freezes after entering my password with the progress bar around 75%. I can login in Safe Mode, usually (sometimes it freezes as well). This behavior seems to have occurred shortly after a system update to High Sierra version 10.13.6.
So far I have tried…
- Complete system reinstall (including erasing the install disk).
- Used Memtest in single user mode, completing 2 passes with no errors.
- Run Disk Utility several times - no errors found.
- Run Apple Hardware Test several times - no errors found.
- Searched for incompatible login issues (of course there should be none post reinstall).
Has anyone else run into this issue? Any suggestions for other things to try?
Frustrated
