I have a MacBook Pro with the M2 Pro chip.
My current desk setup is that I use my MacBook Pro closed (clamshell mode) connected to a OWC Thunderbolt 3 dock, which also connects two 24" 1080p Dell screens. I’m thinking of adding a 34" Ultrawide UWQHD (1440p) monitor to my setup in addition to the existing displays.
Apple’s website states that the M2 Pro can support two external displays with UP TO 5K resolution.
My question is since none of the displays are 4K/5K, and the internal display will not be in use (since the laptop is closed). Will my M2 Pro be able to drive all three screens when connected to the dock?
When I went from Sequoia to whatever MacOs 26 was called, the display almost became unreadable - e.g. dialogue boxes and the like did not have borders and it was hard to work out where they were amongst other things,
I upgraded to Golden Gate and there was not much improvement.
I spent three hours on the phone with Apple support and we came up with a fix but the next time I logged in, back to the old problems.
In the end, I spent the USD100 and used Fable to solve the issue. It said:
this isn’t a Mac mini fault — it’s how Tahoe and its successor render on a 1× external display. If the work machine drives a Retina-class (4K/5K) monitor, you’re unlikely to see it. If it’s another 1440p or 1080p panel, you would, and step 2 is the answer there too. I’d hold off upgrading it until the mini is sorted.
The fix was to install BetterDisplay. Fable thought the settings I needed would be in the Free version, but I had to pay for it:
- Click the BetterDisplay icon in the menu bar (not the settings window). Find the section for the U2715H.
- Look for a HiDPI toggle. In recent versions it’s usually a small button or switch in that display’s block, or in its Resolution submenu. Turn it on. The screen will flicker while it re-handshakes.
- Open that display’s Resolution list again. You should now see entries marked HiDPI, such as “2560×1440 HiDPI”, “2304×1296 HiDPI” and “1920×1080 HiDPI”. Pick one.
- 2560×1440 HiDPI keeps everything the same size as now, just rendered sharper.
- 1920×1080 or 2048×1152 HiDPI makes everything larger and even easier to read, with less space on screen.
If there’s no HiDPI toggle in the menu, go to BetterDisplay Settings > Displays > DELL U2715H > Overview. Tick the HiDPI option there; it may sit alongside “flexible scaling” or “smooth scaling”, which you’ll need to enable too. Then pick the HiDPI resolution from the menu bar as above. Some of these options may sit in BetterDisplay’s paid tier, and it will say so if they do.
Once it’s working, go back to “Edit default resolution” and set the default to the HiDPI mode you chose, so it sticks across reboots. It currently says “2560×1440 LoDPI”.
The resolutions etc. might be different as you have different monitors.
The short story is that natively, no it won’t support 3 external screens.
if Apple says 2 External displays, that’s all it will support out of the box whether you have the internal screen open or closed.
There were some weird configs (I think maybe the MBA M3) which would either support 2 external, or 1 internal and 1 external display.
There are ways around it with software or hardware tricks, but I’ve rarely seen anyone who loves the results. E.g. with some hardware setups, you can make the Mac think that two Displays are actually one display, but this limits your ability to extend across them.
Before you spend any money, an easy way to test is to borrow a monitor (of any size e.g. 1080) off someone else and see if you can get it to work.
In addition to what Wrothie mentioned, check the available refresh rate that your Mac will allow for that additional external monitor.
Adding it might work with your M2 chip, but at a much lower refresh rate than what the monitor is capable of
As much as I appreciate your reply, I’m not quite understanding how this relates to my question. Are you saying that using BetterDisplay can assist in enabling a third screen?
No. I misunderstood your question although reading it back now I see you did say you wanted 3 screens, not replacing one of the existing screens.
