I bought a Magic Keyboard for my iPad 11” and it is really nice - fun to type and the touchpad is really awesome!
But I have one question: It does not stay whe tilted in the furthest back position. It feels like something is pressing back from the furthest back position - like some rubber is to stiff so that it is pushing it back. Is this normal? Is this getting better over time? I would very much like to tilt the iPad as far back as I can.
The unlike the main hinge, the end of its range of tilting motion isn’t sharply defined with a lock-into-place feeling, so it may seem to spring back very, very slightly. But, not so much that I’d describe it as you do; yours may be defective.
I have put something underneath the iPad to keep the hinge open, and it seems to be getting better. I assume it is some rubber which is a bit stiff. I still have a few days to check it. Thanks
