I know it’s an old(ish) thread but I’m playing catch-up…
A managed switch allows you to segment one or more ports into a separate virtual LAN (VLAN). This enables you to divide the network into sections based on use. For most people, in a home environment, it’s probably overkill. You will also need a VLAN router to route traffic between the VLANs (or prevent traffic through the use of firewall rules).
I have a 24-port TP-Link managed switch at home and I’m running five VLANs currently: virtual (VMs running assorted functions, e.g. AD domain controller, file shares, Docker instance - for Plex and others), physical (anything that is plugged in, so laptops, desktops, NAS), external (PS4, Xbox One, Sky+, Sonos), management (UniFi controller, switch, router, APs), lab (segregated network for testing stuff for my day job).
Handling the routing is a UniFi Security Gateway and Wifi is provided by two UniFi AC APs, one at the front of the house and one at the back - the latter being connected via TP-Link powerline adapters.
I have four WiFi networks/SSIDs, one for each of the physical, external and lab networks, and one for a Guest network. The USG and UniFi controller software manages all these.
Everything pretty much manages itself. Occasionally I’ll fire up the UniFi app on my iPhone to get a status update, check traffic stats or print out some more voucher codes for the Guest network.
If you’re getting powerline adapters, make sure you get ones that do at least 1Gb. In my experience you’ll never get that speed as many factors will affect the throughput, mainly the wiring in your house. I get around 80Mbps which is good enough for the devices at the back of the house to connect to the internet.
I think that just about covers it.
The TL;DR version:
- basic requirements with a few devices, use the ISP’s router
- more complex requirements, lots of devices, multiple APs - UniFi gear
