Cbales
#1
I’m looking for a mastodon client which does:
- most recent items are at the bottom, not the top (nobody does this)
- sync read between iPhone and iPad apps (ivory does this)
- If unread is higher than x (maybe 100) quick scroll button to start from y (probably also 100) so you have a finite number to go through.
- See boosted posts only once, (maybe once per day)
Honestly, if you’re using Mastodon, you should buy Ivory by Tapbots. It’s the best.
Cbales
#3
Ivory is good, but it only does one of those 4 things, as far as I know.
Ice Cubes has a different complimentary feature set, and there are things that only the Mastodon website does.
Ivory has the ability to build filters, e.g. filter out boosts, and/or show only boosts. (Read the Macstories review)
As you said, no-one does latest at the bottom, and I doubt anyone will do volume based unread presentation
