I’m thinking of a future plan to replace my existing iMac 5k with an M1 MacBook Air/Pro in the short term.
My issue with using a retina macbook in the past is pairing it with a display that gets anywhere close to the iMac 5k.
Can anyone recommend a display that would provide a nice single USB-C/Thunderbolt connection with power delivery and a a decent resolution.
JohnAtl
December 8, 2020, 1:28pm
#2
I suspect, but do not know for sure, that LG panels are used in 5k iMacs.
But anyway, this should meet your requirements.
Thanks,
Yes Im aware of the LG Ultrafine. In an ideal world something for well under 1000 pounds/dollars would be great.
Prepared to take some hit on image/panel quality and tick the boxes on single cable connectivity.
stu_w
December 8, 2020, 7:14pm
#5
Just to open up your options… Consider pairing a Thunderbolt dock with a ‘regular’ / non USB-C/Thunderbolt monitor. That’s what I did and the combination of Monitor + Dock was still way cheaper than the newer version of the same monitor that had USB-C built in.
