Moom + Automator
I have a MBP that I connect to a 27" monitor when working from home. After hearing the guys talk about Moom I decided to give it a try and it’s awesome! I also went further down the rabbit hole and created a workflow that opens all of my “work” apps.
Right now, I hit one keyboard shortcut to run the workflow and open all of the apps then another keyboard shortcut to trigger Moom and arrange said apps.
Any idea how I can get that down to one keyboard shortcut? I tried assigning the same keyboard shortcut to both, but Moom overrides the shortcut and the workflow won’t run. I also looked at adding Moom to the workflow, but that doesn’t seem possible.
Two keyboard shortcuts is fine, but I’m having fun with this and wanted to see if I could be even more efficient. :smiley:
I like your thinking, but the problem is the second action is just a general keyboard shortcut for Moom, it’s not a part of Automator. I may be missing something, but I don’t see away to “fire off” Moom via Automator.
I completely misunderstood. Sorry.
Have you looked at Brett Terpstra’s Bunch app?
That looks pretty cool, but I don’t think that gets me any further than where I am now. It looks like that would just replace what I’m currently doing in Automator.
What are you using to create your keyboard shortcuts?
Nothing… I created a service for the Automator action to which I assigned a shortcut. Then I assigned a shortcut within Moom.
How about if you combined the Automator and Moom actions in a shell script and then run the shell script with a keyboard shortcut?
Do you have Keyboard Maestro installed?
You could have that fire of both items with one shortcut.
:flushed: Oh man have you sent me down the rabbit hole. Yes, Keyboard Maestro works perfectly for this.
There goes many hours of my life… and $36 :joy:
I’ll make it worse for you: KM can do it all natively…
