Mountain Duck, Expandrive or Cloudmounter
Sounds like the start to make a feature request to limit the size for the Cache folder.
Mine is only 20 GB.
JJW
Hi, I’m wondering what you’re currently using? Can I clarify that you’re searching for a way to virtually mount cloud storage and that way you only fill your drive temporarily via the cache instead of a permanent offline copy?
i’ve used both MD, Cyberduck and Forklift. i’ve stuck with MD because it mounts like an external drive (all about the GUI) and mounts OneDrive. FWIW, MD is on Bundlehunt
