Hey all,
I’ve spent an enormous amount of time exploring options to mitigate storage woes on a new iPhone. I’ll give the quick summary version of my issue and steps I want to take to resolve it and need help validating from experts in this community that this solution route is possible and not fraught with bear traps or issues.
TL;DR Version
iPhone system data and Photos indexing are maxing out new 17 Pro 256gig phone storage, need a temporary solution until the 18s come out and we get one with a much bigger storage drive.
Issue:
-My wife’s Photos library is massive, 300k photos/14k videos it is all synced to iCloud
-We got her a new iPhone (12 Pro → 17 Pro 256gigs)
-The problem: The 17 is having issues indexing and caching files from iCloud for her photos library, the storage is always full due to system data caching so it’s choking the phone.
-Syncing is working fine, photos are still being uploaded but the caching and indexing of the massive library is taking way too long and choking the storage creating a bunch of different issues
-Yes, Optimize iPhone Storage is active on all devices and has been
-Funny enough the iPhone 12 Pro is fine, it’s sitting at about 200 of 256 gigs used for everything on the phone because it had so much time to index and cache the photos over the last 6 years (I digress)
The Plan and steps I need help validating will resolve this issue:
Goals:
-Free up the 100+ gigs that Photos says its using on the 17 by disabling iCloud Photos Sync and Remove Photos from Phone (keep everything in the iCloud)
-Allow photos to be taken on the 17s local storage
-When we get her a new 18 Pro 1TB re-enable iCloud Photos to sync iCloud library and merge local photos into the iCloud library
Steps I need to help validating:
-Turn off iCloud Photos and Remove all Photos from the 17 (keep everything in the iCloud)
-Any new pictures taken will be stored locally on the phone (option to manually upload to iCloud if need be)
-After we get a new 18 Pro 1TB and have transferred all data from the 17 re-enable iCloud Photos Sync
So the things I want to triple check:
Disabling iCloud Photos Sync on the 17 and removing from the phone will not touch any stored pictures in the iCloud (understanding that they need to be synced first)
Re-enabling iCloud Photos Sync on the 18 after a data transfer. I want to triple check that this will not wipe the iCloud Photos library that it will properly merge with the local library on the phone with the iCloud, cache and index the Optimized versions of the photos (with that option selected before turning the sync back on)
Thank you if you took the time to read this thread and respond, really appreciate it I’ve been pulling my hair out trying to find a solution to this problem.
