Noob VM Question
OK. Here is a noob question. I have a M2 Pro Mac. I want to use VMware to run a virtual machine and to install Kali Linux in a VM. Can I install the x64 version? or do I have to install the ARM version?
You’ll have to install the ARM version.
ARM version, I installed it on Parallels, most of the tools will need to be rebuilt using ARM, but should not be so bad.
