Thanks Rob. It’s not really working the way I wanted. I also contacted the ABYY support team, but that might take some time so I’m asking you.
I import the article into ABYY FineScanner and then perform the OCR - in Danish and English - of the article.
I then send the document via the share sheet to PDF Expert, yet I can’t perform any valid searches in that app.
Have you experienced this problem?
Link to video of the problem: https://share.icloud.com/photos/08JM0X1PzpO5CCPa0fYqh5dkg
Hey Andreas,
Been there myself. Actually it’s very simple, although not very straightforward:
First you got to tap the pdf button below and only then you’ll be presented the OCR’d file to export. See screenshot from
iPhone version bellow:
Hi Andreas,
Here is an example with an image from Affinity Photo,
I exported a PNG, did the OCR and then opened it in PDF Expert and searched the file…
Thanks! But that’s not what I see when I scroll to the bottom after having done the ocr the way that @Rob_Polding also showed.
What am I missing. I isn’t see anything at the bottom
