I feel this should be easy enough, but it’s not. Someone shared a OneDrive folder with me and gave me access. I want to make a backup of that folder to my NAS or B2. I do not have OneDrive installed on my mac, I use the web version because the data is too much.
Do you just have a link to their folder on OneDrive (in which case Transmit and similar clients like CyberDuck will not work), or do you actually see these files synced to your OneDrive (have a look on the OneDrive website)?
If it’s the latter, and you’re using Synology, then Cloud Sync might work. It can sync any cloud storage to NAS (using one-directional or bidirectional sync).
It’s a link to their folder in OneDrive, it’s not in my actual OneDrive. After digging on the website. It’s a Sharepoint folder (OneDrive Business). @cornchip the Sharepoint is currently holding 10TB of data
