I use the option key all the time to jump from one word to another or to delete a whole word as I’m typing and it’s stopped working, pretty much, for this specific use. It still works for keyboard shortcuts just not for jumping over words as I type.
I’m not sure if it has to do with the Monterey update?
Interestingly, I can use it as expected in Chrome, but it doesn’t work in Alfred or Mail or Safari. Is anyone else experiencing this? Either way, any ideas for how to troubleshoot?
It’s working fine for me on both internal and external keyboards.
Some things to try to narrow down the cause (these may be obvious, sorry…)
have you accidentally changed the keyboard layout, which may affect option shortcuts?
is this occurring with both the right and left option key?
go to System Preferences > Keyboard > Keyboard > Modifier Keys and swap the option and command keys around. Do the functions still not work in the new position? Do the cmd functions all work now they’re on the old option key?
I’m thinking that a problem which occurs on that physical key only (a hardware problem) may be different from one which stays with the option key (possibly software).
I got a notice of a Karabiner update this morning. It’s now at version 14.2.0. Have you updated recently? Nothing in the release notes suggests it’s related, but…
When I do this, I make sure the app is not set to start at login, then I quit the app, then reboot. Maybe I just added unnecessary steps but that’s what I do.
I’m running 14.2.0. Oddly, the option key works as expected to navigate text typed in input boxes in Chrome (but not Safari). I can use it as I type this message, but I can’t type an en or emdash. And I can’t navigate text with it in address bar in Chrome.
I removed all login items and it still isn’t working properly, however I turned on “guest account” and logged in that way and it worked as expected. So, it seems like it’s a user preference or app thing on my main account.
I’m not sure what happened but I went into System Preferences > Keyboard > Input Sources and added ABC, removed US and Hex, tested, it worked, and re-added UW and Hex and removed ABC and it still works.
