@mikeschmitz I was wondering if you’ve thought of making a version of your Personal Retreat Handbook that is a fillable PDF?
I’m getting prepped for another one and would find a computer fillable version much more useful. I prefer to type and then I can save each one digitally as part of a review next time.
In particular I’d really like the Wheel of Life to be more generic, with a way for me to change what 8 main areas are my focus. I have 8 Areas of Focus that do not quite fit your model. Sure, I can scratch the headers out and write over it but I’d like to have a cleaner version.
That’s a great idea. Let me dig into this and see how much work it is (my Illustrator skills are not great). No promises for how quickly I can get it done
I would also set 8 different areas, and if it makes it easier I would be happy with them being regular horizontal fields rather than curved
What I’ve done so far is import them to Notability, use the white pen to hide the current text, and then write in my own fields - an easy to implement workaround!
Me too or even just the concentric circles with a horizontal text field to add in like a flag label out the side.
For me the circle motif does provide a create representation about whether my life is in balance. If one side of the wheel is low it’s like a flat tire and needs work.
